You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
Quick Tips
DNN error with stack trace
Last Post 01/30/2015 10:26 AM by
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Martin Zajicek
01/29/2015 10:28 AM
i need help with this problem, i moved my local website to live site over mywindowshosting.com
i uploaded all files, attached database and edited connection string which seems to be working because i tried it on my local instance and site worked fine, i tried to find answer what could be problem that im getting DNN error page but cant find solution
this is stack trace from log file when i access site
2015-01-29 07:38:39,393 [Win5081][Thread:51][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
System.NullReferenceException: Object reference not set to an instance of an object.
at DotNetNuke.Framework.DefaultPage.InitializePage()
at DotNetNuke.Framework.DefaultPage.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
2015-01-29 07:38:39,393 [Win5081][Thread:51][ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?error=terminate
2015-01-29 07:38:39,440 [Win5081][Thread:51][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoin)
--- End of inner exception stack trace ---t
anyone has idea what is the problem and how to fix it ? thanks in advance, im really clueless and desparete
DNN MVP
01/30/2015 10:24 AM
Have you been running a DNN installation on this host?
Some things to look at:
Did you also edit the PortalAlias table in the database to include the correct domain?
It does appear that the website is "working" as the error messages are coming from DNN, but do check the IIS settings to make sure that everything is ok.
Also, check file permissions.
If this works on your local site, but not on the host, then there are some problems on the host, assuming that everything is copied over ok. So, if all else fails, delete everything and recopy the installation.
Joe Craig,
Patapsco Research Group
Complete DNN Support
DNN MVP
01/30/2015 10:26 AM
Also, make sure that the application pool your website is residing in is using same version of ASP.Net and pipeline mode.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Quick Tips
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
