You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Custom Modules Does not seem to work
Last Post 01/14/2015 10:18 PM by
. 1 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
yigit balin
01/14/2015 2:52 PM
Hey All;
I am working with a company creates custom modules within DNN . We did a fresh install of 7.3.4 and installed/moved one of our custom module to DNN. Now, we can not add another module to DNN. The link or any other link under Module section does not click.
Also, something seems to be wrong with the extensions. When you want to click on edit, its the same problem, it seems like the link is broken or can not get into it.
We tried :
1 - Jquery disable/enable. In 7.3.4 , you cant even do it seems like.
2 - Added a code to web.config regarding to jquery, it crashed the website.
3 - Nothing under host > Event Viewer.
We are running :
Windows 2012 r2 Datacenter edition
SQL 2014
VS 2012
IIS 8.5
The same instance DOES RUN on Windows 7 box without any issues with the same DNN , SQL 2014 and VS2012
Thanks for any input.
Christian
DNN MVP
01/14/2015 10:18 PM
Do I understand that one installation works and one doesn't? If so, you want to look carefully at the IIS configuration and the website configuration in IIS to see what might be different between the twol.
Visual Studio should not be an issue.
Are both running IIS 8.5? If not, that is where I would look first.
Another thought: can you install DNN on the "non-working" server, and install other non-custom modules successfully? If so, you will want to look at the module compilation and packaging process.
The company that created the custom modules should be able to work this out.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
