<providers> <clear /> <!-- Configuration for AspNetSqlMembershipProvider: connectionStringName="string" Name corresponding to the entry in <connectionStrings> section where the connection string for the provider is specified maxInvalidPasswordAttempts="int" The number of failed password attempts, or failed password answer attempts that are allowed before locking out a user?s account passwordAttemptWindow="int" The time window, in minutes, during which failed password attempts and failed password answer attempts are tracked enablePasswordRetrieval="[true|false]" Should the provider support password retrievals enablePasswordReset="[true|false]" Should the provider support password resets requiresQuestionAndAnswer="[true|false]" Should the provider require Q & A minRequiredPasswordLength="int" The minimum password length minRequiredNonalphanumericCharacters="int" The minimum number of non-alphanumeric characters applicationName="string" Optional string to identity the application: defaults to Application Metabase path requiresUniqueEmail="[true|false]" Should the provider require a unique email to be specified passwordFormat="[Clear|Hashed|Encrypted]" Storage format for the password: Hashed (SHA1), Clear or Encrypted (Triple-DES) description="string" Description of what the provider does --> <add name="AspNetSqlMembershipProvider" type="System.Web.Security.SqlMembershipProvider" connectionStringName="SiteSqlServer" enablePasswordRetrieval="true" enablePasswordReset="true" requiresQuestionAndAnswer="false" minRequiredPasswordLength="7" minRequiredNonalphanumericCharacters="0" requiresUniqueEmail="false" passwordFormat="Encrypted" applicationName="DotNetNuke" description="Stores and retrieves membership data from the local Microsoft SQL Server database" /> </providers>
