Joseph
Thanks for your suggestion...
I've looked and downloaded
http://www.dnncreative.com/Tutorial...fault.aspx the files that you indicate...
What did I see... there has to be another video that you've posted where you've explained to work with the Bootstrap3 for skinning a dnn 7 site.
Because you copy that map... tot start.
In the searchbox... I can't find it on your site. Neither in the Training & Tutorials menu section of your site.
Click on Skinning tutorials... then you find only the 2 bootstrap videos of version 2.3.2.
Can you help me a little bit.
Thanks in advance.
Kind regards
