Yes I found the registration settings under “Site Settings” as you suggested Joe.
I also received the following DNN article through my Resellers Choice support team;
http://www.dnnsoftware.com/communit...istrations Once in there though, I realised that it wasn’t any of the health sites that generated the spam registrations. (Despite the website title “Natural Health, Herbal Remedies”)
The website that generated the spam was a later model of DNN, and as such had the Captcha available. Again your suggestion was correct Joe, and the spam continued even after activating capture.
Seems like the “Captcha Crack” was already a built-in function in this particular spam program.
I then proceeded to set the registration criteria to “verified”. This probably stopped the registrations, but I still get a row of notifications from the auto responder about failed mailing.
I will have to change it again to “Private”, or in case that doesn’t work have to go for the option of remove registration “None”.
It’s a pain, but I guessed is not much to do about the idiots out there making life difficult for us.
Thanks for your help - and have a great one.
Olle…
