You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Upgrading v5.2.2 to v7.x
Last Post 07/02/2014 8:46 AM by
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Scott H.
06/18/2014 10:38 AM
In your recent video on upgrading from v5.x to v7.x, I noticed that you were upgrading from v5.6. My DNN instance is using v5.2.2. Should I upgrade to v5.6 first, and then upgrade to v7.x. Or, can I go right from v5.2.2 to v7.x?
DNN MVP
06/18/2014 11:50 AM
ALWAYS follow the recommendations at
http://www.dnnsoftware.com/wiki/pag...rade_path.
In your case, upgrade to 5.4.4, and then follow the path.
ALWAYS do your upgrade on a copy of your live site, and then move it once you have tested it to make sure that there are no issues.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Scott H.
06/18/2014 12:19 PM
The DNN suggested upgrade path says, when upgrading from v5.6 to v7, to go through v6.2 on your way to v7. But, your training video goes right from v5.6 to v7.x. Why did you skip over v6.2 in your training video?
DNN MVP
06/18/2014 3:04 PM
Sometimes you can make a jump like that, and sometimes you can't. It depends on what you have installed (modules, etc.)
So ... the safest way to do that is to go step by step, as outlined in the Suggested Upgrade Path.
When I do this, I test after each upgrade. When all is well at a particular step, I make a complete site backup (database and file directory) so that I can back up one step if the next step has a problem.
You can always try to do the upgrade in one step, as Andy did in the tutorial, but you may hit a bump in the process.
Joe Craig,
Steve Aunan
07/01/2014 1:23 PM
After upgrading several DNN5x sites to DNN7, I've discovered some things that can make the difference between success and failure:
1. Apply a DNN-provided skin and container between major versions (Minimal Extropy, Dark Knight, etc.). Third party skin packs designed for a previous version can throw errors which prevent you from accessing certain parts of the site.
2. Attempt to figure out which modules will not be needed on the future site, and delete them before upgrading.
3. Upgrade all third party modules on the major version before continuing. (This might also be necessary between 6.1.x and 6.2.x.)
4. ALWAYS backup database and files before continuing to the next version. This can save a LOT of time if things go wrong...
5. Cross your fingers.
DNN MVP
07/02/2014 8:46 AM
To this I would add: ALWAYS follow the suggested upgrade path:
http://www.dnnsoftware.com/wiki/pag...grade_path
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
