You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
bootstrap 3 tutorial / menu not working properly
Last Post 02/14/2014 2:36 PM by
Douglas
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Douglas
02/08/2014 12:31 PM
I'm using DNN 6 and doing the Bootstrap 3 Tutorial.
In Video 2 when you add the DDR menu the issue I'm having is that when you resize the browser, the menu is not visible. For example, when you view the skin on a phone, the menu should be vertical -it's not there. The icon with the horizontal lines is visible, but not the actual menu items.
I have checked the code multiple times, everything is correct.
Update:
I replaced the skin folder I created with the "complete" skin folder from the tutorial and still have the same problem. Multiple browsers. Does this simply not work in DNN 6? I read elsewhere on this site that they were compatible.
Douglas
02/14/2014 9:02 AM
Anybody??
DNN MVP
02/14/2014 10:21 AM
Does the menu appear if you click the icon with the horizontal lines?
(Have you tried installing the skin from the tutorial to see if that works. Install the skin, create a test page on your site, and apply the skin to that page.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Douglas
02/14/2014 11:06 AM
Thanks for replying
No the icon does not work
I copied the complete skin file over but it didn't work. I'll try going through the tutorial again to see if I missed something.
Douglas
02/14/2014 2:36 PM
I tried again with the same result.
When I copy the code from the Bootstrap 3 website for the menu, the menu will not collapse.
I copied the "complete" skin from the Tutorial with the same result.
As I mentioned before, I'm using DNN 6. I realize the tutorial uses DNN 7 could that have something to do with it
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
