Good day.
Please some advice here...
I just followed the tutorial
http://www.dnncreative.com/Training...fault.aspx My DNN menu items never show next to each other only vertical.. where can I set this or am I missing something...
Downloaded the latest bootstrap and here is my ascx.
<%@ Control language="vb" AutoEventWireup="false" Explicit="True" Inherits="DotNetNuke.UI.Skins.Skin" %>
<%@ Register TagPrefix="dnn" Namespace="DotNetNuke.Web.Client.ClientResourceManagement" Assembly="DotNetNuke.Web.Client" %>
<%@ Register TagPrefix="dnn" TagName="Meta" Src="~/Admin/Skins/Meta.ascx" %>
<%@ Register TagPrefix="dnn" TagName="MENU" src="~/DesktopModules/DDRMenu/Menu.ascx" %>
<%@ Register TagPrefix="dnn" TagName="LOGIN" Src="~/Admin/Skins/Login.ascx" %>
<dnn:Meta runat="server" Name="viewport" Content="initial-scale=1.0,width=device-width" />
nnCssInclude ID="DnnCssInclude1" runat="server" FilePath="css/bootstrap.css" PathNameAlias="SkinPath" Priority="6" />
nnCssInclude ID="DnnCssInclude2" runat="server" FilePath="css/bootstrap-responsive.css" PathNameAlias="SkinPath" Priority="7" />
nnJsInclude ID="DnnJsInclude1" runat="server" FilePath="js/bootstrap.js" PathNameAlias="SkinPath" ForceProvider="DnnFormBottomProvider" />
<dnn:MENU ID="MENU1" MenuStyle="BootstrapMenu" runat="server">
- <dnn:LOGIN ID="dnnLogin" class="inline" runat="server" LegacyMode="true" />
<!--/.nav-collapse -->
<div id="BannerPane" runat="server" class="span12">Test
<div id="LeftPane" runat="server" class="span2">Left
<div id="ContentPane" runat="server" class="span10">
