You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Skin with bootstrap 3 doesn't display properly in IE8
Last Post 01/21/2014 9:27 PM by
Terri
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Tim Nguyen
01/01/2014 10:01 AM
I found out that Due to CSS3 Media query is not supported by IE8, So skin with bootstrap 3 won't display properly as in other browsers...
I did carry out a research for the solution and one of the solutions suggesting me to reference respond.js in the head tag of the page.
I did try a few way to reference it in the head tag, But everything still not working properly in IE8 browser.
Anyone can help me to figure out how to deal with this?
Thanks a lot.
Tim Nguyen
Tim Nguyen
01/02/2014 1:42 PM
Well, the problem has been fixed. Only adding script block <script src="/Portals/js/respond.js" type="text/javascript"></script> in header section won't make bootstrap working on IE browsers. You also need to care about the cdv number as well. The script block should be like this: <br /> <br /> <script src="/Portals/js/respond.js?cdv=23" type="text/javascript"></script> <br /> <br /> I don't know what is the cdv number for, but I my case, I saw some of Script block inserted in header section by Dnn client resource management with cdv number is 23. So I just copy it. <br />
Terri
01/16/2014 5:01 PM
Hi Tim,
I am having the same problem with Bootstrap v3.03 applied as per tutorial not displaying the DDR menu in IE8 when viewed on a deskstop screen in DNN 07.01.01 Community version out of the box. Could you please advise what file the script block you have posted should be added to?
Terri.
DNN MVP
01/17/2014 7:39 AM
You can add the script to the skin file. If you download the "Tutorial References" file, you'll find default.ascx (the skin file) in the \\Complete\Skins\Bootstrap 3 folder. You can add a line right under line 8 just replacing "bootstrap.jS" with "respond.js". Place that in a js subdirectory of the skin subdirectory.
The "home page" for respond.js seems to be https://github.com/scottjehl/Respond where you find more information.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Terri
01/21/2014 9:27 PM
Thanks Joe,
This has done the trick and works well.
Kind regards,
Terri.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
