You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Connection to DB failed
Last Post 11/05/2013 7:09 AM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Donald
11/04/2013 7:00 PM
Hello
I am getting ready to migrate a localhost website to a live site. The localhost site is running on SQL Express 2012 LocalDB.
Following the DNNCreative tutorial, I installed SQL Mgmt Studio Express. I attached the dev site's mdf file then using the Mmgt Studio tools, made a backup. Next I detached the DB and closed Mgmt Studio.
Afterwards, I attempted to run the localhost site, and DNN reports "connection to DB failed". Hmm.. In an attempt for a quick fix, I deleted all of the files in the localhost site, and copied back in all the files ( I had previously copied all of the files into another folder). Even after this, DNN continues the throw the same error.
I am clueless about what was changed when I used Management Studio. Any help would be greatly appreciated.
-DL
DNN MVP
11/04/2013 9:28 PM
Is the database on the same server as the website?
Are there other databases? Can you connect to them? With which method?
SQL Server needs to be able to accept connections. You need to have the database configured to accept connections, and from the user (and password) you are using or with Windows authentication.
There probably are a dozen things that could go wrong. Best if you have access to someone who has SQL Server experience. IF you are using a host with tech support, see if they can help you. (Insert ad here for a good company with good tech support and knowledge of DNN!)
Joe Craig,
Patapsco Research Group
Complete DNN Support
Donald
11/04/2013 10:00 PM
Hi Joseph
It is not the live site that has the problem. The localhost site got hosed after attaching it's DB to Mgmt Studio.
I have several DNN sites on a local computer that I am using for learning, all are using Windows authentication. All sites connect and run (as this one did before attaching to Mgmt Studio). There is single instance of Sql Express installed locally. Each localhost site has its own folder within which is an App_data folder containing database.mdf and database_log.ldf.
This is a connection problem for sure. Mgmt Studio connects to the local site's DB, but DNN does not. Again, the local site was being used daily for dev with no problems.
DNN MVP
11/05/2013 7:09 AM
Have you changed the connection strings in DNN's web.config file so that it points at the SQL Express Server?
You could also detach file database and see if it will connect with that method.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
