Prosper 202 Tracking Install;
Second part is a redirect that need to be installed.
(Have attached the code here as TXT, but install it on the site as a HTML.)
This is a re-direct to the Affiliate Landing page;
Testing with the URL;
http://www.conniehansen.com/CHA_KidneyLP01.html On the website though, it need to be triggered by the above JAVA Script - right?
If so, does this really track 10 - 20 different Hyperlinks and Affiliate banners on the page?
Thanks - any clarification is appriciated - am a bit confused about this.
Cheers
