Hi Joe.
Hope you have a simple solution to this one.
All content on this page disappeared?
http://www.conniehansen.com/Partner...ealth.aspx" target="_blank" rel="nofollow">http://www.conniehansen.com/Partner...ealth.aspx
Are there any easy way to retrieve them?
Or access the HTML Module where I installed the Java Script to clean it out?
(See Attachment.)
THANXXXXXX
Olle....
PS;
I am attempting ti install Affiliate Tracking Code on the sites, and it's a very much PHP based program. But have Java Script options.
http://tracking202.com/home/ Installing the following script in an HTML module on teh page;
Installed under "Basic Editor" And all page content disapeared.
All page settings are OK, as are the heading and menu items on the page.
