You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Can Default DNN Search Results template be edited?
Last Post 04/02/2013 7:04 AM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Dan Rothschild
04/01/2013 4:36 PM
Client would like to remove some items from the search results window. For example, a typical result looks like this:
Search results for l1 visa
1 files - Relevance: 1213
Immigration Glossary Immigration law has a number of highly technical terms that may not mean the s...
Client would like to remove the first 2 lines:
Is this just a simple edit to the aspx or VB file? Can I just comment out the line that calls those 2 items, or is it more involved?
Thanks in advance,
Dan
DNN MVP
04/01/2013 9:29 PM
Dan,
It might be easier to use CSS to set display:none to the items that you don't want to display.
You can try rewriting the .aspx, but you'll hit problems is you remove controls that are using in the code behind file. Then there is all of that "hard to upgrade" stuff ...
Joe Craig,
Patapsco Research Group
Complete DNN Support
Dan Rothschild
04/02/2013 6:53 AM
Hi Joe,
Thanks for the tip. I did it a bit different. I edited DesktopModules\Admin\SearchResults.aspx page and added the line visible="false" to these 2 lines:
<asp:HyperLink id="lnkTitle" runat="server" CssClass="SubHead" visible="false" NavigateUrl='<%# FormatURL((int)DataBinder.Eval(Container.DataItem,"TabId"),(string)DataBinder.Eval(Container.DataItem,"Guid")) %>' Text='<%# DataBinder.Eval(Container.DataItem, "Title") %>' />
<asp:Label id="lblRelevance" runat="server" CssClass="Normal" visible="false" Text='<%# FormatRelevance((int)DataBinder.Eval(Container.DataItem, "Relevance")) %>' />
Best,
Dan
DNN MVP
04/02/2013 7:04 AM
Dan,
That approach is fine, provided that you remember it before doing an upgrade. Chances are that this won't change so you should just save a copy and be prepared to copy it back after the upgrade.
Also, I notice that the SearchResults.ascx.cs file is also there, so you could go about removing elements or adding other ones, provided that you do it carefully.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
