You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Twitter and Facebook buttons in IE8 problem.
Last Post 01/10/2013 10:39 AM by
Bob Worley
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Bob Worley
01/09/2013 9:44 AM
I'm hoping someone can give me some direction on what else to look at for this problem. I've added a Twitter Follow button and a Facebook button on my DNN (3.2.2) website. I generated the code from the Twitter and Facebook developer websites. When I view the website in IE9, everything looks and works fine. When the website is viewed using IE8, the buttons will not display. I tried comparing security settings between the IE8 and IE9 and most settings matched (there are additional settings in IE9 but these were set to enabled).
For the Twitter Follow button, I added a text/HTML module onto my webpage. Added this code into the Text area (Basic Text Box - HTML):
Follow @MySiteName
Then, this script into the header of the module:
<script> <br /> !function(d,s,id){ <br /> var js,fjs=d.getElementsByTagName(s)[0]; <br /> if(!d.getElementById(id)){ <br /> js=d.createElement(s); <br /> js.id=id; <br /> js.src="//platform.twitter.com/widgets.js"; <br /> fjs.parentNode.insertBefore(js,fjs); <br /> } <br /> }(document,"script","twitter-wjs");</script> <br /> <br /> I realize this is primarily DNN questions/issues, and this seems to be more an issue with IE, but I was hoping maybe somebody has run across something like this before trying to implement these buttons into DNN. By the way, when viewing the website thru Firefox, the machine running IE9 still viewed fine, but the machine with IE8, did not. <br /> <br /> Thanks, <br /> Bob
DNN MVP
01/09/2013 6:28 PM
You will note that there are some
tags INSIDE of the script. These are HTML tags they will break the code. I'm surprised that the other browsers didn't break.
(No comment about the DNN 3.2.2 site ... but you really should do something about that.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Bob Worley
01/10/2013 10:39 AM
Joe,
Thanks for the reply. I believe the
tags came as a result of me testing the script inside the text, and then copying it back out, again.
Also, I finally figured out what else was happening...turns out the machines which were not displaying the buttons had ESET antivirus installed which was configured to block *twitter.com and *facebook.com web pages. I removed the block, and the buttons appear.
I totally with you on the DNN 3.2.2 site comment....it's causing me a lot of grief to maintain. I have a few items to clean up, and then we're going to schedule to upgrade to either 6.x or 7. I haven't done an upgrade before, so we're probably going to have to outsource that step...depending on time constraints.
Thank you again. Lesson learned for others out there...don't just pass off looking at your antivirus...it can cause issues.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
