You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Issue 80
Last Post 02/09/2013 7:51 PM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
buc2
12/17/2012 11:03 PM
I am following the 4 videos for installing the HTML5BoilerPlate skin. I have followed each step and saved the files correctly. I've uploaded the skin folder with the files to the Portals>_default>skins
I've downloaded and installed the 49Fingers StyleHelper module.
Now, when I login and try to create a page and use this skin (HTML5BoilerPlate) I can select the skin from the drop down menu and save it. But, I get this error message and have no idea where to go or how to resolve this issue.
I've also tried to see the 49Fingers module listed in the Active Extensions but, don't see anything there with that name. I also attempted to re-install it and a notice says it has already been installed.
Here is the error I get:
Could Not Load Skin: /Portals/_default/Skins/HTML5BoilerXPlate/default.ascx, Error: C:\inetpub\vhosts\bluediamondserver.com\httpdocs\DesktopModules\40Fingers\SkinObjects\StyleHelper\StyleHelper.ascx.vb(1819): error BC30519: Overload resolution failed because no accessible 'Split' can be called without a narrowing conversion: 'Public Function Split(separator() As Char, count As Integer, options As System.StringSplitOptions) As String()': Argument matching parameter 'separator' narrows from 'String' to '1-dimensional array of Char'. Extension method 'Public Function Split(ParamArray separators() As String) As String()' defined in 'System.StringHelper': Argument matching parameter 'separators' narrows from 'Integer' to 'String'. Extension method 'Public Function Split(ParamArray separators() As String) As String()' defined in 'System.StringHelper': Argument matching parameter 'separators' narrows from 'System.StringSplitOptions' to 'String'.
Can you guide me on what I am doing wrong?
Thank you,
Don
DNN MVP
12/18/2012 7:10 AM
First of all, which version of DotNetNuke are you using?
Can you post the line from your skin file that refers to the 40Fingers skin object? I think that the problem is there.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Charles Stanley-Smith
02/07/2013 5:09 AM
Dear Joe,
I've had a sudden outbreak of the same!
1. I have a producttion implementation running 6.2.6 with skins based on this HTML5 - it is OK
2. I have a localhost site on my laptop running 7.0.2
3. It has some pages with the same skin as the production - one with the default HTML5 - some pages with the default Aphelia skin - some with the Minimal Entropy
4. The HTML5 based skins give the error above
5. The HTML5 skins were working until yesterday - at about the time I installed a demo version of EasyDNN News and a demo version of DNNGO News
6. Here is the line that refers to the 40Fingers
<%@ Register TagPrefix="fortyfingers" TagName="STYLEHELPER" Src="~/DesktopModules/40Fingers/SkinObjects/StyleHelper/StyleHelper.ascx" %>
With Best Regards
Charles
DNN MVP
02/09/2013 7:51 PM
Since the problems appeared after you installed two items, I'd look to them as the source of the problem.
Make sure, too, that you have the most recent version of the StyleHelper skin object installed. The error message in the original post refers to a problem with "Overload resolution" and that tends to indicate that the code is trying to do something that has been changed.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
