DNN 6.2
I purchased a skin and have sucessfully added the skin. But I cannot seem to get the portal template that came with the skin installed.
The files skin.template and skin.template resources have been copied into ../Portals/_default/Templates.
From Admin->Site Wizard->Next brings the "Choose a Template for your site" form. Check "Build your site from a template".
Here is the problem. The template list shows only the default DNN templates.
I have 2 questions. Am I approaching this the wrong way? If so how should the skin template be installed?
Or, if I am doing this correctly, how to I get the skin template to show in the Template List of the Site Wizard?
Thanks for you help.
