Back from vacation and onto this issue: I just tried to create a new template and this is the result from the event viewer.
ModuleId: 321
ModuleDefId: 63
FriendlyName:
ModuleControlSource: DesktopModules/Admin/Portals/Template.ascx
AssemblyVersion: 6.1.1
PortalID: 0
PortalName: Human Services Department Intranet
UserID: 1
UserName: host
ActiveTabID: 17
ActiveTabName: Site Management
RawURL: /Host/Portals/tabid/17/ctl/Template/mid/321/portalid/0/Default.aspx?popUp=true
AbsoluteURL: /Default.aspx
AbsoluteURLReferrer:
http://dnndev.hra.co.santa-cruz.ca....popUp=true UserAgent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; InfoPath.2)
ExceptionGUID: 8bcec906-f56c-47c0-9923-0f9b0a26d8ef
InnerException: Object reference not set to an instance of an object.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: DotNetNuke.Entities.Tabs.TabController.SerializeTab
StackTrace:
Message: DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Entities.Tabs.TabController.SerializeTab(XmlDocument tabXml, Hashtable tabs, TabInfo tab, PortalInfo portal, Boolean includeContent) at DotNetNuke.Modules.Admin.Portals.Template.SerializeTabs(XmlWriter writer, PortalInfo portal, Hashtable tabs, TabCollection tabCollection) at DotNetNuke.Modules.Admin.Portals.Template.SerializeTabs(XmlWriter writer, PortalInfo portal) at DotNetNuke.Modules.Admin.Portals.Template.cmdExport_Click(Object sender, EventArgs e) --- End of inner exception stack trace ---
Source:
Server Name:
