You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Issue 78 - How to change tabs color?
Last Post 08/21/2012 9:34 PM by
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Abraham Tameru
08/07/2012 2:47 AM
Many thanks for issue 78, is it possible to change tabs color?
I tried to add a style like style="background-color:#0000FF;" it doesn't work.
DNN MVP
08/07/2012 12:35 PM
Of course you can!
In the tutorial code, the class="dnnForm dnnModuleSettings dnnClear" add classes to the tabs div so that jQueryUI will pick up styles from the default.css stylesheet, where the styles are defined to conform to the standard DotNetNuke styles. If you want to create your very own CSS file, it's probably best to start with one you download and that you modify.
You can, of course, modify those styles, or use your own styles or stylesheet for the tabs. You've just got to get the classes right.
One way to do this is to use the ThemeGallery at
http://jqueryui.com/themeroller/#themeGallery
to choose a predefined look and feel, or use the ThemeRoller tool there to create your own. You can then download a custom CSS file, add it to your DotNetNuke installation, and use it. As an example, leave the extra classes of of the div with id="tabs" and, just before the jqueryui script, add something like this:
< link rel="stylesheet" href="/js/jquery-ui-1.8.14.custom.css" type="text/css" media="all" / >
Here I have placed my custom CSS file in the js directory of the DotNetNuke installation.
Joe Craig,
Patapsco Research Group
Complete DNN Support
DNN MVP
08/07/2012 12:35 PM
I should have said, too, that there is a lot of information about using jqueryUI stuff in the DotNetNuke Wiki at DotNetNuke.com.
Joe Craig,
Abraham Tameru
08/09/2012 3:07 AM
I you told me I download a custom css from ThemeGallery. I copied "< link rel="stylesheet" href="/js/jquery-ui-1.8.14.custom.css" type="text/css" media="all" / > " in the footer before the jquery script
<script type="text/javascript"> jQuery(function ($) { $('#tabs').dnnTabs(); });</script> <br /> It doesn't work. Did I miss something?
DNN MVP
08/09/2012 8:38 AM
You will want to look at the page with some developer tools to see if the css file was loaded.
I assume that you do have a file named jquery-ui-1.8.14.custom.css in your site's js directory. If not, you'v missed an important step: you need to get the custom css file, upload it to your site, and then refer to it with the link tag.
Joe Craig,
Abraham Tameru
08/09/2012 8:57 AM
you're right my jquery file is jquery-ui-1.8.22.custom.css
DNN MVP
08/21/2012 9:34 PM
Did you ever resolve this problem?
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
