You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
Quick Tips
Acces my home page
Last Post 06/01/2012 11:16 AM by
. 8 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Joel
05/28/2012 6:39 PM
Recently i just redirect by url my home page, now :
How can acces againg the page for updating ?
before redirect, i did modification by : www.mypage.com/login.aspx
but now when i try the same, the page is redirect to the url I set.
How do i can acces my web page againg?
Joel
Pingle2009
05/29/2012 2:19 AM
Hi Joel, I'm assuming that you can still log in, in which case go to Admin > Page Management and select Home so that the page settings appear. You can then expand the Link section and reset Link Type to None.
Joel
05/29/2012 7:59 AM
Hi Pingle2009
The problem is i can not login, when i try "www.mypage.com/login.aspx" , the page redirect too to the url i was setting in home page.
I dont know what to do... ???
DNN MVP
05/29/2012 10:30 AM
You are going to have to get into your database using SQL Server Management Studio to remove the redirection.
I assume that you did this using the redirection in page settings. Go to the Tabs table and find the Url column. Delete whatever entry is there for the page(s) in question and that will stop redirection. You may need to manually recycle the AppPool before the changes are effective.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Joel
05/29/2012 4:59 PM
Hi Joe
The big problem is i can not go to any page because when i try "www.mywebsite.com" inmediatly redirect to "www.urlsiteredirect.com" and i can not acces any page of my web site.
On the other hand, when i try to access "www.mywebsite.com/login.aspx" , the login page open , but when i fill the form with user "host" and pasword, inmediatly redirect to "www.urlsiteredirect.com"
I want to delete the url i set in home page of my web site, but i can´t .....
What do i do ?
Joel
05/29/2012 5:01 PM
Excuse me , i forget... yes, i did the redirection using page setting ( in home page ).
thanks
DNN MVP
05/29/2012 10:17 PM
You will have to use the SQL Server Management Studio approach to fix the redirection in the database. If you are hosted, perhaps your host's tech support can do this for you.
Joe Craig,
Joel
06/01/2012 10:53 AM
Hi Joseph .
Can you tell me what is the path and name of the table i am going to fix ?
DNN MVP
06/01/2012 11:16 AM
The name of the table is Tabs and the column is named Url.
Run this query:
SELECT TabId, TabName, Url FROM Tabs
Then you can identify which TabId has the redirect. Then run this:
UPDATE Tabs set Url='' WHERE TabId=XX
but replace XX with the TabId that you want to fix.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Quick Tips
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
