I have some problems using Issue 22 . "Find and Replace SQL queries for DotNetNuke (To fix problems after transferring a localhost database to a live website and other useful functions) By Lee Sykes, July 2007" [
http://www.dnncreative.com/Training....aspx] tutorial to adjust my html code.
When I tried to run the code provided by Kevin Schreiner in SQL server I have the following errors:
Msg 207, Level 16, State 1, Procedure Replace_DesktopHtml, Line 39
Invalid column name 'DesktopHtml'.
Msg 207, Level 16, State 1, Procedure Replace_DesktopHtml, Line 50
Msg 207, Level 16, State 1, Procedure Replace_DesktopHtml, Line 51
Msg 207, Level 16, State 1, Procedure Replace_DesktopHtml, Line 52
