You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Issue: Drop Down Menus not working
Last Post 01/25/2012 3:28 PM by
D Taylor
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
D Taylor
01/24/2012 5:03 PM
Have 5.6.1 in production which shows the fault
Localhost 5.6.1 and upgrades to latest V5, V6 and fresh install of V6 all do the same thing. When adding modules to a page, the drop down list of modules only allows the first item (HTML) to be selected. Can't click and select any other module type.
Other drop down lists have the same fault.
Work around in V5 is to use Classic contral pane. V6 only uses popup menus.
Localhost is Vista with SQLServer 2005 Any ideas?
DNN MVP
01/24/2012 6:30 PM
Which control panel are you using?
Is this with a custom skin? If so, switch to Dark Knight and see if the problem goes away. If it does, the problem is in your skin.
You can turn off the popups on the Host, Host Settings page.
Joe Craig,
Patapsco Research Group
Complete DNN Support
D Taylor
01/25/2012 3:28 PM
Today loaded DNN 6 to Local Host and had same problems with popup windows; ie cannot select from a drop drown menu; also found that I couldn't drag the help boxes. Have today played with DNN 6 having discovered that I could turn on the ICONBAR option in host settings which enabled me to gain access to module adding.
Eventually a thought crossed my mind about COMPATIBILITY SETTIGS in Internet explorer. I am using Explorer 9 on Vista. I turned compatibility settings OFF for localhost - Surprise, surprise; the DarkNight skin is now working correctly! Thanks!
D Taylor
01/25/2012 3:28 PM
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
