Hi Guys,
I need urgent solution for this issue. I have upgraded my DNN website from 5.6.2 to 6.01.01 and upgrade script runs smoothly and everything seems working fine. But i figured out that module definition process is not working. Not only for Custom Modules but for DNN Core Modules as well. When i try to add module definition or update it gives me error "Object reference not set to an instance of an object."
Below is the detailed event log info for this issue.
AssemblyVersion: 6.1.1
PortalID: 0
PortalName: Dotty Bingo
UserID: 1
UserName: Tehseen
ActiveTabID: 36
ActiveTabName: Extensions
RawURL: /Host/Extensions/tabid/36/ctl/Edit/mid/345/PackageID/82/portalid/0/Default.aspx?popUp=true
AbsoluteURL: /Default.aspx
AbsoluteURLReferrer:
http://dottybingo/Host/Extensions/t...popUp=true UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:8.0) Gecko/20100101 Firefox/8.0
ExceptionGUID: 7ba01e16-588c-49c5-ac78-8090315a7b0f
InnerException: Object reference not set to an instance of an object.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: DotNetNuke.UI.WebControls.VersionEditControl.LoadPostData
StackTrace:
Message: DotNetNuke.Services.Exceptions.PageLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.UI.WebControls.VersionEditControl.LoadPostData(String postDataKey, NameValueCollection postCollection) at System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace ---
Source:
Server Name: BDJHB-ITD03
Best Regards,
t
