Hi People..
I decided to stay with the standard / default DNN skin in this new website.
http://www.gcauto.com.au Skin; DarkKnight 2-ColumnRightMegaMenu
Container; DarkKnight PageTitle Red
I now found that the footer panes has a black background that make it very hard to read some text - ie; hyperlinks.
Are there an easy way to change the background in these panes?
Does it have to be done in the skin code?
If so is these skin downloadable?
Or should I look for alternative solutions?
Cheers
Olle...
