You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Cannot find my Link Tracking Tables
Last Post 07/15/2011 6:21 PM by
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
whenry
07/15/2011 2:29 PM
I need to be able to track which users download certain files or access certain pages. It appears that Link Tracking will do what I want but...
I have inserted a Links module, added a couple and turned on Link Tracking. When I display the activity from the module settings screen it shows what I want but i need direct access to it for reports. Everything I see on the web implies that the table dbo.URLtracking is the one I need but the data is not there. So I know it is 'working' but where is the data?
Thanks for your help.
DNN MVP
07/15/2011 6:04 PM
Yes, that should be the table. If you are not seeing results, you should check the Event Log to see if anything is reported that that might indicate a problem. I'm not aware of a way to either disable or enable link tracking.
Presumably you can use the Reports module or a similar one to generate the reports that you need.
Joe Craig,
Patapsco Research Group
Complete DNN Support
DNN MVP
07/15/2011 6:21 PM
Whoops. ALso take a look at URLLog and URLs.
I really haven't dug into these items, but it is the URLLog table that included UserID. So, that is the one that you'll need to look at to identify the users who clicked the link.
URLLog and URLTracking are linked via the URLTrackingID field. On first glance, I can't tell if URLs in related to the other table. I suspect if you look at the tracking information shown in the links module tracking data you can figure this out.
There is a stored procedure in the database called GetUrlLog that will probably be helpful in generating data for a report. I there may be others that are useful. Look at the source code for the Links module where the tracking reports are generated and you can see what is being called. IMHO, it's better to dig around in the namespaces and the database to see what has been created already rather than trying to create it yourself.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
