mbudram
Nuke Active Member Posts:33
06/01/2011 8:11 PM |
Hi i'm pretty sure this is an easy thing and it's there but i'm in the swing of trying to get a project done and haven't explore all the tutorials and forum question. I'm hoping i can get some quick assistance. Basically after someone registers on a DNN portal, can i specify which page they are redirected to after they register?? Thanks for you patient Mervin |
Mbudram |
06/01/2011 8:30 PM |
Yes. Go to the User Accounts page and click the User Settings link. You can specify pages to redirect after Registration, Login and Logout.
mbudram
06/01/2011 10:55 PM |
Thank you. On a different note, what module would you recommend that can manage users on a site where i can easily sort through new users |
Mbudram |
06/02/2011 4:40 AM |
There is a free user management module from DNNWerk at codeplex.com. It is intended to replace the Users and Accounts module and provides some additional features. But, I'm not sure that is what you have in mind. What functions do you need? |
mbudram
06/03/2011 3:02 PM |
I need to create a backend for my client where they don't have to go through lots of steps to manage new users to the site. They want the ability to know when a new user register, and also approve or disapprove a user. They want to know how often users visit the site etc. |
Mbudram |
mbudram
06/03/2011 3:24 PM |
Is there a way i can pull the User information and enter it automatically into a form. I'm making a sign up form but once they are already logged in, I don't want them to have to enter their name, email etc again. |
Mbudram |
06/03/2011 3:35 PM |
Which module are you using to create the form? |
mbudram
06/03/2011 5:54 PM |
I'm using DNN Centric Custom Form Creator, but i'm thinking of switching to Data Spring... |
Mbudram |
06/03/2011 6:09 PM |
I am not familiar with that module. Looking at their website, though: "Intelligent default values: You can use dnn tokens, or session variables or query strings to initialize default values of various fields" So that does seem quite easy to do. if you do switch to Data Springs Dynamic Forms you can set default values for form fields in lots of different ways including user and site parameters, querystring variables and SQL queries. |
mbudram
06/03/2011 6:44 PM |
Thank you Joe, is there a tutorial on how to work with default values for form fields in lots of different ways including user and site parameters, querystring variables and SQL queries... I haven't worked with it before. And as i'm working i'm coming up with more question it seems, I for sure need to spend more time going through the available tutorials, So i've created a custom registration page, but how do i get the registration form on that page... it seems i can only add the account login module... |
Mbudram |
mbudram
06/03/2011 7:06 PM |
I figured out the registration form... |
Mbudram |
mbudram
06/03/2011 7:07 PM |
I figured out the registration form module. |
Mbudram |
mbudram
06/03/2011 7:29 PM |
Hi Joe, I figured out the registration module. So my idea in simulating a subscription form didn't work as i planned... probably need to rethink to flow chart. Do you know of any subscription module that's similar to what Amazon does when vendors sign up to sell on amazaon... https://sellercentral.amazon.com/gp/on-board/workflow/Registration/login.html?passthrough%2F&passthrough%2Faccount=soa&passthrough%2FsuperSource=OAR&passthrough%2FmarketplaceID=ATVPDKIKX0DER&passthrough%2Fld=AZFS-30 |
Mbudram |
James Bradworth
Nuke Newbie Posts:2
07/22/2011 10:32 AM |
hello |
[url=http://massagechairreviewsite.net/inada/inada-sogno-dreamwave]inada sogno dreamwave[/url] |
PWM
Nuke Pro Posts:66
12/14/2012 8:27 AM |
Hello, How can i do this in DNN 6.2.2 ? Thanks in advance Regards |
12/14/2012 9:11 AM |
Go to the User Accounts page and click on the tab for User Account Settings. You will be able to specify redirect pages for After Login, After Logout, and After Registration. |
PWM
Nuke Pro Posts:66
12/14/2012 9:33 AM |
Hi Joseph Craig, Thanks but, i don't have that settings. In the tab for User Account Settings, i don't have that settings. Here's a screen shot: http://img29.imageshack.us/img29/3875/usersettings.jpg Thanks Regards |
PWM
Nuke Pro Posts:66
12/14/2012 10:05 AM |
Finally i find it: Admin > Site Settings > Registration Settings > Redirect after Registration Thanks anyway Regards |
12/14/2012 10:19 AM |
Sorry. That page of settings has moved recently. I'm glad you found it, though. |
