You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Admin Menu Missing in new Portal
Last Post 07/12/2011 2:49 PM by
Packet8i
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Jo-Anne Satterly
05/29/2011 3:43 PM
I exported my portal 0, with content which has skin and various modules. I created a new module, with this new template but it didn't import completely and looks like it failed on creating the menu (although the new Admin user was made and linked to the usual roles). In the SQL tabs table, the admin tabs are missing but many of the other module menu records are there.
Is it possible to "send" these again from portal 0 to portal x? I really don't want to try to create another portal if possible with all the rest in there.
Thanks very much,
Jo
DNN MVP
06/02/2011 1:26 PM
Which version of DotNEtNuke are you using?
I assume you meant to say that you created a new Portal with the exported template. Can you tell how or where it failed?
The admin tabs should be present for each PortalId. THe Host tabs are not repeated for each portal and show up in the tabs table with PortalId=NULL.
Joe Craig,
Patapsco Research Group
Complete DNN Support
WSI B2B Marketing
07/05/2011 8:07 AM
Joe,
I'm having a similar issue with the admin tabs going missing on newly created and imported portals. Ours seem to be failing during the site wizard process. We create new portals using the default template and then login with that new portals admin and use the site wizard importing the exported portal.
I have a funny feeling it's during the 'ignore / replace / merge' option, but even so, they should still be there.
Bottom line is there a way to reimport ONLY the admin interface into a portal (maybe using the 'replace') option?
Any help would be appreciated, we have 3 portals where the entire admin menu didn't copy over. In some cases it only has 'new page' as an option and in others it has 1/2 the options.
Again thanks for all the assistance and general resources here, you guys have saved me alot already.
thanks, ben
DNN MVP
07/05/2011 10:38 AM
Joe Craig,
Packet8i
07/09/2011 4:08 PM
i am using DNN ver 5.6 and having the same issue..missing Admin menu.
DNN MVP
07/11/2011 7:42 AM
My memory is that this was an issue in that version of DotNetNuke. Fixing the menus requires editing the database.
First, though, you should upgrade at least to 5.6.2.
If you could give me access to your site, I can take a look and verify that the problem I am remembering is the one that you are experiencing. If you want to do that, contact me privately using the Contact form at patapscorg.com.
Joe Craig,
Packet8i
07/12/2011 2:49 PM
Dear Joe,
I have PM you the details as suggested.
regards;
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
