You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
database synchronization of dotnet nuke and asp.net application
Last Post 05/19/2011 8:48 AM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Ritesh Baranwal
05/18/2011 7:34 AM
Can i synchronize the data(transfer the data) from dotnet nuke application to the ms sql server database which is connected to asp.net application.
The data from table1 in dotnetuke database must be transferred to table1 in ms sql server database (which is being used by the asp.net application)
Can the above process be possible ?
Please post your comments on this. If possible please explain this with an example.
With Thanks & Regards,
Ritesh
DNN MVP
05/18/2011 8:33 AM
Yes. This is possible. And, there are tools available to do this.
However, if you want to simplify things and do things according to "best practices" you should not try to keep the two databases synchronized. Instead, why not have your asp.net application read data from the DotNetNuke database when it is needed. I would not recommend writing to the DotNetNuke database from the external application.
Perhaps if you could explain your need for the DotNetNuke data, it will be easier to make a suggestion.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Ritesh Baranwal
05/19/2011 12:41 AM
Hi joseph,
my requirement is to read the data of one table of dnn application which you told is easy and secure. But the problem is i dont have the location of the db file. when i saw the connection string of dnn application, i got this connection string
But if you see this connection string in datasource is coming as .\SQLExpress. so i have a doubt like if i use this connection string to read the data from table yhen will it work or not.
so what is the solution for this because to read the data i need the connection string.
Plz reply asap.
Thanks and regards
Ritesh
DNN MVP
05/19/2011 8:48 AM
I'm not sure that I understand. You have the connection string. Why are you not able to use it?
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
