Andy Stephenson
![Nuke Master](https://www.dnncreative.com/DesktopModules/activeforums/images/Ranks/blue_square_06.gif) Nuke Master Posts:54
![](https://www.dnncreative.com/profilepic.ashx?userId=50958&h=80&w=80)
![--](https://www.dnncreative.com/DesktopModules/ActiveForums/images/spacer.gif) |
Thomas Smith
![Nuker](https://www.dnncreative.com/DesktopModules/activeforums/images/Ranks/blue_square_02.gif) Nuker Posts:13
![](https://www.dnncreative.com/profilepic.ashx?userId=1522&h=80&w=80)
04/29/2011 9:53 AM |
Where do I get the PSD files for this skin? The post states the PSD's are available, yet I can't find a link to the download. Thanks! |
Earning our stripes... everyday. imagesmith.com |
Chris Howell
![Nuke Newbie](https://www.dnncreative.com/DesktopModules/activeforums/images/Ranks/blue_square_01.gif) Nuke Newbie Posts:1
![](https://www.dnncreative.com/profilepic.ashx?userId=8822&h=80&w=80)
04/29/2011 10:30 AM |
I don't see any link to download either. |
![](https://www.dnncreative.com/profilepic.ashx?userId=6961&h=80&w=80)
04/29/2011 10:34 AM |
You have to be a subscriber and you have to be logged in to see the download link. And, it does appear that the PSD files are missing. Hopefully we'll get that fixed soon. |
Bravo
![Nuke Newbie](https://www.dnncreative.com/DesktopModules/activeforums/images/Ranks/blue_square_01.gif) Nuke Newbie Posts:4
![](https://www.dnncreative.com/profilepic.ashx?userId=25035&h=80&w=80)
04/29/2011 11:44 AM |
The skin does not interact well with Smith Cart buttons. All the buttons are blank... |
04/29/2011 1:46 PM |
It is often the case that modules need to be styled to match skins. The Clear Blue Skin includes styling for the Blog Module. While I haven't looked at this skin in detail, I imagine that you can add styles for the Smith Cart that match the skin. If there is a site that I can look at, I'll be happy to see what I can figure out for you. |
04/29/2011 1:48 PM |
When you say that the buttons are blank, does that mean that the text on the buttons disappears? If you drag your mouse pointer over the buttons, can you highlight the text? If so, that means that the color of text on those buttons needs to be styled to a different color. You will need to identify the classes for those buttons and change the text color. |
Bravo
05/10/2011 12:03 PM |
I have worked with Rick at DNNStyle on a cusom project. I appears you have a relationship with him and DNNStyle. I have another project I would like to discuss this him/you. Let me know if there is an interest... I have been unable to contact Rick directly. |
05/10/2011 12:22 PM |
There is a Contact page at dnnstyle.com. |
Bravo
05/10/2011 12:31 PM |
Thanks, I was afraid of that... I have tried without any luck. |
Jorge Hernández
![](https://www.dnncreative.com/profilepic.ashx?userId=64571&h=80&w=80)
05/16/2011 5:05 AM |
Why cannot I download the skin Charleston Gold Skin for Dotnetnuke 5x ????. My account is active but cannot access to several skin in this page.
05/16/2011 8:47 AM |
As it says on the page: "Download Charleston Gold Skin Released on Friday, June 3rd." The free skins are being released one a week. So, check back in a couple of weeks for that one. |
Fredrik
![Nuke Newbie](https://www.dnncreative.com/DesktopModules/activeforums/images/Ranks/blue_square_01.gif) Nuke Newbie Posts:3
![](https://www.dnncreative.com/profilepic.ashx?userId=49125&h=80&w=80)
05/23/2011 3:38 AM |
This is really great! Allthough I wounder can I edit the themes to fit what I need for my site? For example remove "terms of use" and the search textbox and...? I looked at the license with the skin but it seemed to be for when you have bought it from dnnstyle. Or does the same rules apply? Thank you guys for a really great site! |
05/23/2011 10:45 AM |
I don't believe that there are any issues relative to modifying the skin for your own use.
Jim
![](https://www.dnncreative.com/profilepic.ashx?userId=29721&h=80&w=80)
06/26/2011 6:54 PM |
I have tried 2 of the skins, Clear Blue and Copper. I experience the same error with each. I add an HTML module and when I try to edit content, I get the message: Error loading "/Providers/HtmlEditorProviders/Fck/FCKStyles.asp?tabid-1830" FCKStyles.asp is in the directory and I have no trouble when I use other skins. I am using DNN 5.6.1 (238) and the HTML module is up to date at 5.6.1 Any ideas? |
06/27/2011 9:55 AM |
Is it looking for FCKStyles.asp or FCKStyles.aspx? It should be the latter, and you should not have a file named FCKStyles.asp. I just installed Clear Blue on my test site and applied it to a page. I had no trouble with the FCKEditor. So, I'm not sure what is happening here. There doesn't appear to be anything odd in the skin file that could cause this sort of problem. If you don't mind experimenting, you could edit your web.config file so that you use the Telerik editor and see if that causes a problem. We have a tutorial "How to Configure the Telerik RAD Editor in DotNetNuke" if you would like to try that. |
Donald Riley Posts:10
![](https://www.dnncreative.com/profilepic.ashx?userId=4533&h=80&w=80)
06/28/2011 4:59 PM |
Well this question is not about the Free Clear Blue Skin, but it's where your DNN Styles Skins link took me. I am looking for the Fashion Skin which was supposed to be released on June 23, but is still not available for download. Do you know when it might be available? |
LetItShine
![Nuke Ace](https://www.dnncreative.com/DesktopModules/activeforums/images/Ranks/blue_square_04.gif) Nuke Ace Posts:47
![](https://www.dnncreative.com/profilepic.ashx?userId=27752&h=80&w=80)
07/03/2011 12:40 AM |
Posted By Jim on 2011-06-26 06:54 PM I have tried 2 of the skins, Clear Blue and Copper. I experience the same error with each. I add an HTML module and when I try to edit content, I get the message: Error loading "/Providers/HtmlEditorProviders/Fck/FCKStyles.asp?tabid-1830" FCKStyles.asp is in the directory and I have no trouble when I use other skins. I am using DNN 5.6.1 (238) and the HTML module is up to date at 5.6.1 Any ideas? I am having the same issue. When I apply the free Charleston skin and attempt to edit the content of an html module, i receive Error loading "/Providers/HtmlEditorProviders/Fck/FCKStyles.asp?tabid=39" These two very nice skins are created by the same company. Ths solution will probably apply to both skins. Has anyone figured this one out? |
07/03/2011 9:40 AM |
Please do the following test: Apply a Minimal Extropy skin to the page and see if the problem continues. Please let me know the result. |
07/03/2011 9:53 AM |
If the editor is really trying to load FCKStyles.asp and not FCKStyles.aspx, then ... this from the DotNetNuke forums might be helpful: http://www.dotnetnuke.com/Resources...posts.aspx Before making changes, though, please look at the relevant section of the web.config file and see if this line: DynamicStylesGeneratorPath="~/Providers/HtmlEditorProviders/Fck/FCKStyles.aspx" Says asp or aspx. If it says asp, then it might simply be that you need to change asp to aspx. Try that first and see if that fixes the problem. |
