Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
Oscar Im
 Nuke Newbie Posts:5
06/03/2009 8:33 PM |
I am running v5.0 and can't seem to locate the MESSAGE_PORTAL_PRIVACY.text and MESSAGE_PORTAL_TERMS.text file in the language editor. |
mlorence
 Nuke Active Member Posts:32
04/04/2010 11:27 PM |
I followed this path to edit the terms and Privacy areas and now I have the entire text listed twice. First what I entered and the default test as well. How do I get rid of the default text. I am running dnn 2.02.02 community edition.
Marion
04/05/2010 7:44 AM |
Are you really running 2.02.02?
Could you provide a URL for the site?
mlorence
04/05/2010 8:48 AM |
Is it possible that you've somehow added a second copy of the module to each of the pages?
Do determine that, look at the pages in Edit mode. Do you see two modules? If you do, delete the one that you don't want.
mlorence
04/05/2010 9:22 AM |
No. Please note the screen shot of admin>languages area which does show 2 editing areas. Each of them include the corrected message I require, yet when viewing my privacy page, there are 2 different messages. Here is the url. http://mailhandling.com.dnnmax.com/Privacy.aspx |
04/05/2010 9:48 AM |
That is the normal appearance of the Language Editor page. The editing box is on the left. The right display is the default value for the text.
mlorence
04/05/2010 12:31 PM |
In Admin>languages>Local Resources I do see Prviacy.ascx under Portal>Local Resources and under Skins>LocalResources. Same thing with Terms.ascx. Could that be where the duplication is coming from? See print screen
04/05/2010 1:13 PM |
No. You need to look at the Privacy.aspx page itself, and see where the second instance is coming from. Could you look at that page in Edit mode and see if there are multiple modules?
mlorence
mlorence
04/05/2010 5:39 PM |
OK........... Here is what I did. Created my own Privacy and Terms pages, made links to them in my custom footer section, edited the skin.css file to make the copyright statement centered and set the original privacy and terms tokens to display: none; Here is the result. http://mailhandling.com.dnnmax.com/...actUs.aspxMarion |
04/06/2010 6:07 AM |
Clicking the Privacy link gives:
A critical error has
occurred. You
have been redirected to this default Login Page because the Login Page
set for this website does not contain a valid DotNetNuke Account Login
module, or the permissions have not been set correctly.
You have some permissions and login module issues.
mlorence
04/06/2010 8:56 AM |
Thank you. I made the needed adjustments on all counts. I was using a Coding Staff module for login and now replaced it with the default module. Also checked the viewing permissions for my new Privacy and Terms pages.
Marion
Web Development Officer
 Nuke Newbie Posts:5
02/14/2014 2:08 PM |
I was having trouble with the Terms of Use in the footer, and so I deleted the module, thinking that I could re-add it, but now I see it is not so easy. I would like to add the default Terms of Use back onto the website. I am running version 7.00.05. I’ve looked in AdminLanguages and cannot find anything referring to Terms of Use. I’ve looked in AdminExtensions and found a Languages module, but again I cannot find anything referring to Terms of Use. Leanne |
02/15/2014 11:31 AM |
Terms and Privacy are not modules, but are Skin Objects. When you say you delete the module, what did you delete? If you actually deleted a module, look in Admin, Recycle Bin to restore it. Is it possible that your site was using an HTML module with custom language for Terms? Then you should be looking in the Recycle Bin. |
 Nuke Newbie Posts:5
03/03/2014 2:29 PM |
Hi Joseph, Sorry, I thought I would have received an email when a message was posted and didn't notice your response until just now. The Terms of Use used to appear at the bottom of the home page. I deleted it (or rather the module it was in?), thinking that I could simply add it back on. However, I can't figure out how to add or recover it. I've checked the Recycle bin and cannot find anything there. If it is a skin object, I will contact the third-party developer and hopefully resolve the situation that way. Thank you for your help. Leanne |
03/03/2014 4:25 PM |
Yes, Terms and Privacy are Skin Objects. But, it seems like you had a module linked to a Terms hyperlink. If you deleted a module, it should be in the Recycle Bin. If it isn't, something else is going on. |
