New DotNetNuke Cloud Application HostingStop over paying for dedicated and private DNN servers or cloud hosting
services. You can now get the best true Hyper-V Windows DotNetNuke private
dedicated cloud hosting services
starting at only $45.00 for a limited time from
ResellerChoice
The New DotNetNuke Cloud Application Server:
ResellerChoice
revolutionary DotNetNuke cloud application hosting offers the ability to rapidly deploy
applications such as DotNetNuke but also allows for applications like WordPress,
Joomla, Dedicated SQL, Forex, etc...
Your virtual instance will include your selected hardware configuration,
Optimized operating system for your application and an installed copy of your
application selection customized to your specifications.
Migration services for
existing applications are available, We will even move
your DNN site for you!.Configurable Hardware
Our configurable options allow you to pick and choose the exact hardware
specifications you need. These options can also be changed on a monthly basis
making our solution as elastic as you need it to be.
Configurable options:
Memory
CPU Cores
Disk Space
Operating System
Cloud Add-On Services (Available add-on services for your cloud instance such as monitoring (basic host
ping included), backups, management, etc...
Sign
up for our new private cloud server application services
Chat with us and our 24/7 365 support.
