Introducing the Caliper Skin Pack for DNN - with Mega Drop-Down Menu!
PackFlash has just released the first commercial DotNetNuke (DNN) skin which employs a Mega Drop-Down menu. This skin, called Caliper, is the first DNN skin on the marketplace to use the PackFlash Mega Drop-Down System.
MANY COLOR PALETTES INCLUDED
The Caliper Skin package has many options which provide flexibility when applying the skin to your site. Number one: the skin comes in over a dozen different color palettes (18 different variations). The palettes were created to provide a neutral structure for web content, along with accent colors which can be optionally applied through the use of the 11 different DNN containers that come with the skin package. Most other commercial skins utilize only a single color per skin. The option to include an accent color on the page really enhances the ability to call out particular content.
SUB-MENU OPTION
The skin also contains different layout options. The most basic choice is whether a particular page should include only the mega menu navigation in the header, or if a sub-menu (left navigation) should also be shown in the left column.
The DotNetNuke Caliper Skin Design by PackFlash
can be seen running currently at
DotNetNuke Skin Caliper Package Demo
If you have any questions or need anything related to this skin, please contact us at 888-433-2260, use the forums on the PackFlash website, use the contact forms on the website, or email us at
success@packflash.com
