You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
How to create a side feedback tab
Last Post 01/03/2011 1:46 PM by
Fred Sommer
. 7 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Fred Sommer
12/19/2010 2:28 PM
I would like to place a side feedback tab on one of my websites. How is this done? Is it a skin item or can it be achieved with a module?
Thanks.
DNN MVP
12/19/2010 2:54 PM
I probably woud do this in the skin.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Fred Sommer
12/19/2010 3:00 PM
Thanks. I've never really messed around with altering skins other than by using the tools that come with a skin pack. Can you suggest a resource I could visit to learn how to this?
Thanks.
DNN MVP
12/19/2010 3:28 PM
Here is a quick think that you can play with to get a handle on how to do some things. This is done with a Text/HTML module.
Add a Text/HTML module to the page, set the container to not be displayed, and turn off the visibility and print features. Get into the Raw mode of the editor and use this as the contents of the module (removing the extra spaces around the < and > brackets):
< div id="myTest" >< /div >
Add this as your CSS
#myTest
height:200px;
width:30px;
font-color:red;
background-color:red;
border:2px solid black;
position:absolute;
top:400;
left:0;
This example will create a rectangular block that is absolutely positioned on the left side of the screen. I like to play with things like this using Web Developer Toolbar (if Firefox) for the developer tools in IE so that you can play with the CSS and see how it affects what you are doing.
In practice, you would use a background image for the link, and add a link.
If you are doing this with a module, you'll need to set the module to display on every page.
If you are doing this in a skin, just add the div to the skin. Put is somewhere out of the way so that it doesn't interfere with other things. Near the top is a good place.
Joe Craig,
Fred Sommer
12/19/2010 3:31 PM
Thanks Joe! I appreciate the quick response.
I'll give it a try.
Fred Sommer
01/03/2011 11:59 AM
I was able to create the side bar tab but I cannot figure out how to get it to trigger a feedback module. I'm using the iWeb Feedback module which has a pop-up mode. From their help screen it says "You can customize any skin object into form trigger button in popup mode using the jquery selector. For example: #Feedback." In the module settings you can specify the name of the object you want to use for the trigger. I asked this question via their support desk but I have not received an answer yet so I decided to see if anyone here can help me.
What code would I need to put in the html code I used to create the tab in order to trigger the pop-up form? I'm using
David Tang's Feedback Tab jQuery Plugin
to generate the tab.
DNN MVP
01/03/2011 1:38 PM
Fred,
Can you give me a link or reference to the feedback module?
Joe Craig,
Fred Sommer
01/03/2011 1:46 PM
Here's a link to the actual module -
http://www.interactivewebs.com/Defa...ckdesigner
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
