Coding Staff is proud to announce a release of its
SharePoint Banner Web Part
Coding Staff SharePoint Flash Banner and Slideshow is a professional sharepoint web part that you can use in various ways. SharePoint Banner web part could be used as SharePoint Image Rotator web part, SharePoint Slideshow web part or SharePoint Flash widget. The web part has a set of effects you can use for your SharePoint slide show, SharePoint photo gallery or SharePoint banner. Effects are manageable and you are even able to combine them.
Web part supports: WSS 3.0, Sharepoint Server 2007, Sharepoint Server 2010
Web part requires: .NET Framework 3.5
You can also take a look at its
Live Demo
