Hi Lee,
With issues I have mentioned with UCanUse after installing DNN 4.4.1, I decided to go through your tutorial on a custom registration form.
Here is what I set up:
To keep it simple for the user, the basic information on the initial page - First name, Last name, display name, and email.
I continued to add the accept terms custom property. Now, even though, at this point, I would like to have seen this property on the initial page, it is required, and showing on the page they get to after they login in on a verified portal instance.
Here is the problem:
Everything worked as expected in your tutorial, until, that user came back in and went to manage their profile (user being me testing). I managed profile and unchecked the accept terms tick box. Now, I thought by logging out and then logging back in, I would have been confronted with the second screen asking me, again, to accept the terms. Nope.
Am I missing a step?
