You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Skinning Toolkit
Skinning Toolkit
Skin Package Question
Last Post 11/03/2010 12:19 PM by
. 11 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Scott
11/02/2010 7:54 PM
I followed the SuperStyleSheets tutorial and created my skin. Now I was going to package it for installing on a DNN installation. I started watching the How to Package a DNN5 skin tutorial. But, I don't see my skin on the extensions page. There seems to be a disconnect. In the SuperStyleSheets tutorial we copy folders to make our new skins. In the packaging tutorial you install a new skin before packaging it up. Can anyone help me?
DNN MVP
11/03/2010 7:14 AM
I think that the idea is to add the skin to a local (test) site by copying them to a folder in Portals/_default/Skins. This actually installs the skins in your site. Then, you can use the tools built into DotNetNuke to create the manifest file and package the skin.
Note that this works only for ascx skins. Also, if you have containers, you will need to package them separately. If you want to include skins and containers in the same file, you can take the two packaged skin and container files and combine them. You will also have to combine the two manifest files.
You don't have to do things this way. You can package them outside of DotNetNuke if you create a proper manifest file.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Scott
11/03/2010 8:21 AM
Right now my new skin is part of a local site. My skin is in the Portals/_default/Skins folder. I am using it on one page in this site. I am pretty sure what I have made is an ascx skin because I followed the SuperStyleSheets tutorial to make the skin. I just changed a few things in the skin.css file. I just don't know what to do next for packaging it since I cannot see this skin when I go to Host->Extensions. Frustrated by this, I copied my skin folder to a different local site. I put it in the Portals/_default/Skins folder. I logged in as admin, clicked on the icon to edit the settings for this page to try to apply the skin. I cannot see the skin here either, so I am totally confused now. I don't know what I am doing wrong. Everything I do seems to be logical to me, but I obviously am missing something.
DNN MVP
11/03/2010 9:01 AM
Can you see the skin and apply it to a page using the functions in Page Settings for a page or for the site?
Joe Craig,
Scott
11/03/2010 9:10 AM
I can on the site that I developed the skin. I cannot on the second site where I copied the skin folder to the Portals/_default/Skins folder.
DNN MVP
11/03/2010 9:17 AM
That is rather odd. Double check that the directory structures on the two sites are the same.
Joe Craig,
Scott
11/03/2010 10:04 AM
They look the same to me. I've attached a couple of images showing the paths.
DNN MVP
11/03/2010 10:11 AM
Make sure that the files are the same inside of the DHI_SuperStyleSheets directories.
Joe Craig,
Scott
11/03/2010 10:44 AM
Yep, they are the same. Which is to be expected since I just copied the folder from my skinning development site over to the other site. Maybe we should take a step back though. Remember I can't see my skin when I go to Host->Extensions on my skin development site. But, I have applied it to a page within my development site. In fact, to test it again I just created a new page and applied my skin to the new page. Also, I can see my skin in Host->Host Settings and also in Admin->Site Settings. I just can't see it in Host->Extensions.
DNN MVP
11/03/2010 10:54 AM
I think I'm more confused now than at the beginning ...
I'm not sure that I can offer any more help without looking at the two sites.
Joe Craig,
Scott
11/03/2010 11:57 AM
I'm sorry to be so confusing. They are local sites on my machine so that isn't going to work. So, if I create a skin all I have to do is copy it to the right folder in a DNN installation and then the skin should be "installed" and I should be able to use it on any portal in that DNN installation? This is my understanding, is this correct?
DNN MVP
11/03/2010 12:19 PM
That is correct.
What is confusing is that you aren't seeing the skins on the Extensions page.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Skinning Toolkit
Skinning Toolkit
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
