You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Add logout Link to RibbionBar Control Panel
Last Post 09/30/2010 7:18 AM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Kevin Verver
09/29/2010 12:44 PM
Hi, I am trying to add a logout link to the RibbonBar Control Panel. I have added the <%@ Register TagPrefix="dnn" TagName="Login" Src="~/Admin/Skins/login.ascx" %> to the ribbionbar.ascx page and tried to put the <dnn:Login runat="server" id="dnnLogin" /> control in that file but I get an error about the login control does not have a public id or something like that assigned. Thanks for your help. Kevin
DNN MVP
09/29/2010 6:38 PM
That's not likely to work. That is a skin object and is meant to go into a skin. The ribbonbar.ascx file is not a page, but a control.
What is it that you are trying to do? (I often put the User/Login skin objects inside of conditional code when I want them available to logged in or admin users. Joe Brinkman has a current blog entry about using conditional codes in skins. Look for it in the blog section at dotnetnuke.com.)
Joe Craig,
Patapsco Research Group
Complete DNN Support
Kevin Verver
09/29/2010 6:52 PM
Thanks for the reply. I just need a logout link to appear only when someone is logged in and not all the time.
DNN MVP
09/30/2010 7:18 AM
Put something like this in your skin:
< % If Request.IsAuthenticated Then% >
< dnn:USER runat="server" ID="dnnUSER" CssClass="user" / >
| < dnn:LOGIN runat="server" ID="dnnLOGIN" CssClass="user" / >
< % End If% >
(You will need to remove the spaces I put after < and before > in the above.
This will insert the USER and LOGIN objects, but only if the user is logged in (Request.IsAuthenticated). There are lots of other things like this that you can do.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
