We are using DotNetNuke Community Edition 5.2.3(74)
Currently DNN is installed in IIS under a web site. In otherwords,
the URL to access the default installation is https://mysite.ca/DNN.
We are trying to setup couple of parent portals using this
DotNetNuke installation.
Here are the steps that we followed.
- From Host->Portals->Add New Portals, we created a new parent portal.
the url : mysite.ca/english. Interesting thing is that the template
used to create this site is in turn created from the site running under
There are no errors and I click on the hyperlink, the site doesn't
get loaded. Now I go to IIS Management console and create the Virtual
directory for 'english' and copy all the required files and the web.config
is also modified to connect to the new database.
Still when I enter htts://mysite.ca/english, it gets redirected to
https://mysite.ca/DNN only. Any idea what I am missing..?
I know that DNN creates a separate folder under portals, the index of the
newly created portal.I even copied the files under that folder.
Still the same result.
With Regards
SA
