Hello Steefow,
I appreciate all of the advise, I have not liked the way the
menu structure has looked and I have had no idea how to fix it my self, but know that I know what is wrong from your suggestion I will have someone take a look at it.
The
Google Top Pane is a empty module that I am using putting my Google Adsense code in the header section. That is the only way that I can get the Google code to work.
I agree with getting ride of the high contrast blue containers, but there is not enough time in a day, as for editing the content I completely understand and wish I could find someone to help with that. I emplemented the changes of "warming device" and "make shift" that you suggested.
Thank you for the great advise and if you have any more input please let me know. If anybody else wants to check out my site they can do so by going to
www.answerstocaraccidentquestions.com
Thank you,
Merle
