You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Vertical Align not working properly in Safari
Last Post 08/19/2010 2:45 PM by
mbudram
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
mbudram
08/17/2010 5:51 PM
I'm not sure if this is the place to write about this but i spent a 2 days searching online and not finding a solution. Pretty we just recently launched a site using DNN 4.09. It was a custom skin i made for the site and my issues is as follows:
I have a left that i want the content to always lock to the bottom of the page. I'm using tables to layout the site so for that cell, i set the valign="bottom" which works in both IE & firefox but for some reason in Safari, its align to the top and would not align to the bottom. Is there some I'm doing wrong? here's the code for that section: I bold the section
<dnn:SOLPARTMENU runat="server" id="dnnSOLPARTMENU" rootonly="true" display="vertical" rootmenuitemcssclass="MainMenu_TabRootMenuItem" rootmenuitembreadcrumbcssclass="MainMenu_TabRootMenuItemSel" rootmenuitemselectedcssclass="MainMenu_TabMenuItemHover" Rootmenuitemactivecssclass="MainMenu_TabMenuItemSelHover" submenucssclass="MainMenu_SubMenu" submenuitemselectedcssclass="MainMenu_SubMenuItemSelHover" UseArrows="false" UseSkinPathArrowImages="false" UseSubMenuBreadCrumbArrow="false" UseRootBreadCrumbArrow="false" />
<div id="BottomLeftPane" runat="server" visible="false">
<td valign="bottom" id="BottomLeftPane2" runat="server" visible="false">
Mbudram
DNN MVP
08/17/2010 6:06 PM
You might get some help from
http://css-tricks.com/what-is-vertical-align/.
There are some comments regarding safari near the bottom.
What kind of doctype are you using?
Joe Craig,
Patapsco Research Group
Complete DNN Support
mbudram
08/18/2010 8:36 AM
I'm pretty new in a sense to DNN and skinning. I'm using the ASCX method and I don't have a doctype in the skin.ascx file. should there be one???
Mbudram
DNN MVP
08/19/2010 6:40 AM
If you'll look at some of the skinning tutorials, you'll see that you should have a doctype file associated with every skin file. So, if you have an index.html or index.ascx skin file, you should have and index.doctype.xml file.
In the newer versions of DotNetNuke, there is a "fallback" doctype setting in the Host Settings. I believe that this will be active if a doctype file is not present for you skin.
Joe Craig,
mbudram
08/19/2010 2:45 PM
Thanks for you time and input. I appreciate it. I added the doctype.xml file and still no success... Here's the link of the site
http://www.kaanabelize.com.
In firefox and IE its show correct but in Safar, the Follow us area on the left that should be locked to the bottom is aligned to the top.
Mbudram
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
