I am creating a new container for my skin. I need help in editing the module menu background.
When I select the menu in the container options, its background is transparent which makes it hard to see the text such as "Settings" and "Delete".
I need to know what class is usually associated with the container menu options.
I started skinning from the DNNBLUE Skin.
Any Help will be appreciated
Regards Michael
