You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
DotNetNuke Telerik RAD Editor Introduction - Issue 59
Last Post 12/21/2012 10:37 PM by
. 10 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
08/02/2010 3:14 AM
Add any comments or questions regarding the
tutorial from
Issue 59
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Jernej
11/10/2010 12:20 PM
Can I use Replace Tokens in RADEDITOR?
DNN MVP
11/10/2010 12:40 PM
Yes. You will need to go to the settings of the HTML module and check the box to enable token replacement. And, the tokens aren't replaced until the page is rendered.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Jernej
11/10/2010 1:14 PM
Can I define my custom portal token?
DNN MVP
11/10/2010 6:21 PM
No, there is no provision for defining custom tokens.
Joe Craig,
David Kroll
04/30/2011 11:44 PM
I added a Flash .SWF file to my website using the Telerik RAD Editor's Flash Manager, and it works fine on both my Macbook and my Windows PC, but as expected, it does not display on my iPod Touch. How would I go about displaying an alternate file, such as a .JPG or animated .GIF, for mobile devices such as the iPhone and the iPod Touch, that don't support Flash? Thanks.
DNN MVP
05/01/2011 7:37 AM
I'm a real fan of the free DigFlash module from DigNuke.com. One of the module settings is the HTML content to be displayed if there is no flash player. So ... you just put your content there and you are done with it.
The editor embeds the flash file as an object, not a swfobject. I think that is a much less flexible approach than using swfobject.
If you need to do this in a text/html module, I'd recommend that you look at the html that DigFlash generates and use that in your module.
Joe Craig,
David Kroll
05/02/2011 1:50 PM
Thanks, Joe! I ended up using SWFObject 2 (
http://code.google.com/p/swfobject/...entation),
since I'm not sure if DigFlash is using the most recent version of SWFObject, but I added their link to my notes and will keep them in mind. I hadn't heard of SWFObject until a few days ago, so this information was definitely helpful. Thanks again.
DNN MVP
05/02/2011 1:58 PM
DigFlash 5.4.2 is using SWFObject v2.2.
Joe Craig,
Anastasios Stellas
12/21/2012 3:30 AM
Hi all,
I am new to this forum and I really do not know if you have discussed it before.
I am trying to insert a link. I write the test, select it, press the link button and the pop up window that is coming up, contains an error and not the standard functionality interface of the editor. This happened suddenly yesterday, by the time that I was trying also to insert a link. An error came up (which I didn't keep as I thought that the issue will be solved with a simple logoff - logon proccess) and since then the link functionality of the editor is "destroyed"!
Could you please help me on this?
Would you like to post something more in order to help you define the issue? Thank you in advance!
DNN MVP
12/21/2012 10:37 PM
Could you post a screen shot of the error and any text?
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
