Hello Lee:
I am new to DotNetNuke and downloaded the Community Edition yesterday and I am using Visual Web Developer 2008 Express.
I installed DotNetNuke and created my first test site. But that was yesterday. How do I access my site under construction? Google can’t find the local host. When I use VWD and click the view website link the program works well but when I close VWD the program malfunctions. I have VWD set to dynamic ports because I think it doesn’t work so well on fixed ports. Also the program loads very slowly.
I would like to see a tutorial on accessing the websites under construction.
Also can an installation of DotNetNuke be copied to another folder and renamed or is a fresh installation required?
So far I have found your tutorials very helpful and easy to follow and this was quite persuasive in choosing DotNetNuke.
