Thanks Joe!!
I tried different install with the same problem, even installing existing modules supplied by default failed.
I ended up deleting all files in wwwroot, and the database - and then run a new "Application Install in the C panel. I ended up with the following error;
00:00:43.140 - Installing Optional Packages:
00:00:43.140 - Creating Portal: My Website
00:00:49.561 - Error: Object reference not set to an instance of an object.
00:00:49.561 - Portal failed to install:Error!
Installation Complete
After contacting Resellers Choice I got the following reply;
The DNN appears to be installed correctly, are you still having trouble with this install?
If so, do you just want us to manually install this for you?
So I proceeded with installations of Modules, Skins and user account. And everything looked great.
UNTIL THE SITE GOT STUCK IN SOME ADMINISTRATOR MODE???
Check it here;
http://www.mepstarshop.com/" target="_blank" rel="nofollow">
http://www.mepstarshop.com/ I gave the following to Resellers Tech Support, and might need to start all over again....
Everything seemed to install alright, and I added some users, skins and modules.
Now suddenly it seemed to have got stuck in some administrator mode?!?!?
No admin or host menu, but the top toolbar are there permanently and are working.
Please check here;
http://www.mepstarshop.com/ If you see the top toolbar just as visitor, - Please reinstall the DNN manually.
THANKS!!
