Buck Anderson
 Nuke Active Member Posts:24
01/13/2007 7:47 AM |
I have a menu that has finally stumped me. If anybody can point me in the right direction, I sure would appreciate it. Lee, I noticed this same problem showed up in a picture in the skinning toolkit.
The submenu has a image and when you first dropdown, I have whitespace around it. As you move your mouse, they disappear.
The site is a temp site at http://new.marconet.com and I have the solutions menu with a submenu.
TIA Buck
Here is the code and I have attached a pic of the problem:
/***** Main Menu *****/ .MainMenu_MenuContainer { background-color: Transparent; } .MainMenu_MenuBar { cursor: pointer; cursor: hand; background-color: Transparent; } .MainMenu_MenuIcon{ display:none; } .MainMenu_Arrow{ display:none; } .MainMenu_RootMenuArrow{ display: none; } } .MainMenu_MenuItem, .submenuitembreadcrumb { cursor: pointer; } .MainMenu_MenuItemSel { cursor: pointer; /*background-color: #F99F00; color: #CD0012; font-family:Verdana, Helvetica, sans-serif; font-size: 11px; font-weight: bold; font-style: normal; padding-top:4px; padding-bottom:4px; padding-left:25px; border-right: white 2px solid; padding-right:25px;*/ } .MainMenu_RootMenuItem, .MainMenu_RootMenuItem TD { cursor: pointer; color: white; font-family:Verdana, Helvetica, sans-serif; font-size: 11px; font-weight: bold; font-style: normal; padding-top:4px; padding-bottom:4px; padding-left:25px; border-right: white 2px solid; padding-right:25px; } .MainMenu_RootMenuItemSelected, .MainMenu_RootMenuItemSelected TD { cursor: pointer; color: #CD0012; font-family:Verdana, Helvetica, sans-serif; font-size: 11px; font-weight: bold; font-style: normal; padding-top:4px; padding-bottom:4px; padding-left:25px; border-right: white 2px solid; padding-right:25px; background-color: #F99F00; } .MainMenu_RootMenuItemActive, .MainMenu_RootMenuItemActive TD { cursor: pointer; color: #F99F00; font-family:Verdana, Helvetica, sans-serif; font-size: 11px; font-weight: bold; font-style: normal; /*border-left: red 10px solid; border-bottom: orange 10px solid; border-top: purple 10px solid;*/ padding-top:4px; padding-bottom:4px; padding-left:25px; border-right: white 2px solid; padding-right:25px; background-color: black; } .MainMenu_MenuBreak{ border:0px; padding:0px; } .MainMenu_SubMenu { z-index: 1000; cursor: pointer; background-image:url(SubMenu-background.gif); background-color: #FACB4C; height: 18px; color:black; font-family:Verdana, Helvetica, sans-serif; font-size: 11px; font-weight: bold; font-style: normal;
padding-top:0px; padding-bottom:0px; padding-left:28px; padding-right:0px;
filter:progid XImageTransform.Microsoft.Shadow(color='gray', Direction=135, Strength=4); border:0px; border-color:black; border-style:solid; border-right: 1px; }
.MainMenu_SubMenuItemSelected, .MainMenu_SubMenuItemSelected TD { background-color: #C0C0C0; border:0px; border-color:#C0C0C0; border-style:solid; }
/* END Main Menu */ |
Buck Anderson
JustNorth Outdoors - www.justnorth.com Jive Media - www.jivemg.com |
Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
01/13/2007 9:28 AM |
If you wish to remove the horizontal white line, these are caused by styles in the default.css file, you need to override them in your skin.css file using: .MainMenu_MenuItem { border : 0 } - or remove the border section in the .MainMenu_MenuItem class in the default.css file. Once you have overriden these, you also have some white lines on the right hand side, these are caused by the .MainMenu_MenuArrow class in the default.css file, you can override them in your skin.css file using: .MainMenu_MenuArrow { border: 0 } Or again delete the border code from this class in the default.css file. I found the solution to these problems by using the techniques outlined in this tutorial: Troubleshooting DotNetNuke Skins (2 videos - 17min)- It's worth a watch as it will save you a lot of time troubleshooting skins. PS. - The skin.css file is loaded up twice, double check in your skin.htm file that you have not put a link to the css file in there. - You can see which css files are loaded using the web developer toolbar - all details in the link above. Hope this helps, Cheers, Lee |
Buck Anderson
01/13/2007 12:27 PM |
Thanks Lee,
If I would have asked you first, I could have saved myself a day of frustration. Hey, there's a testimonial for you...
I also learned about the link to the css file in the html module. Never knew that. What a difference in some of my load times.
Is the proper procedure to leave the link in while you are testing and editing your html (I use FrontPage) and then remove it when you install the skin to your site?
BTW - have you ever considered converting the videos, on the site, to FLV format and allowing the ability to view online in a flash player?
I have been doing that on a couple of our sites. I can get a 35 mb wmv file down to 6mb.
Thanks again, Buck |
Buck Anderson
01/13/2007 12:39 PM |
Hi Buck,
No problem, glad it was useful. Yes I use that procedure. It makes it easier when testing and editing skins in a WYSIWYG editor.
The videos are in Flash format which as you say, makes them much smaller than any of the other formats. Some of the videos are available to view online in a Flash player as introductions to the tutorials, but the rest are downloadable in a zip file. This makes it much easier for subscribers to download several tutorials at once.
Thanks, and happy skinning,
Cheers,
Lee |
Buck Anderson
01/13/2007 12:49 PM |
Lee,
What have you been using for a flash player?
I can get mine to work if I place the player and the swf file in a html page and then add it to a IFrame mod. Not very swift. Curious to know how you got a flash player to work in DNN.
TAI Buck |
Buck Anderson
Buck Anderson
01/15/2007 10:47 AM |
Hi Lee,
I will check these files out. Bass player huh? Blues guitarist myself.
I have had trouble getting hosts to support flv here in the states. Life goes on.
Here is a post you might be interested in.
http://www.ventrian.com/Support/Pro...aspx#16906
Have a great day and enjoy the outdoors, Buck justnorth.com jivemg.com |
Buck Anderson
01/15/2007 2:25 PM |
Hi Buck,
Yes I play quite a few instruments, started on the flute and progressed to piano, electric guitar, and even did a few years of Balinese gamelan! and somehow I've ended up playing bass for the past few years.
I didn't realise there was an issue with hosts and FLV files I just uploaded them and it worked, guess I'm lucky...
Thanks for the heads up over at ventrian.com - it's appreciated,
Cheers,
Lee |
Buck Anderson
01/17/2007 8:09 AM |
Hi Lee,
Too bad we have an ocean between us. Be fun to get together and jam.
Have another question on the solpart issue. Two actually.
1. If you compare http://new.marconet.com, you will see on the first site's menu that the menu renders cleanly when hovered over (no jerkiness as the sub menu drops down). If compared to the later, same test, it does not seem to understand the 18px height that I assigned to each cell. Any thoughts?
2. Unrelated. If you compare the following:
http://www.marconet.com/VC_Solution...x and http://new.marconet.com/Solutions/V...tions.aspx
If you compare the whitespace and first black horizontal line, you will notice on the later, there is more whitespace below the solpart menu than the original page. This happens as soon as I add a text/html module for the small picture in the top, left hand corner. The image is 140x90 and lines up perfectly with the bottom of the solpart menu. If I shink the image height, then the gap between picture bottom and horizontal line image shins. But, then the image does not line up with the bottom of solpart menu.
Is this caused by DNN whitespace rendering? I am on DNN 4.3.7. |
Buck Anderson
Buck Anderson
01/17/2007 8:11 AM |
Sorry too early in the morning. horizontal line image shins - should be horizontal line image shinks
TIA Buck |
Buck Anderson
Buck Anderson
01/17/2007 8:41 AM |
Lee, it appears that the image spacing issue can be resolved by adding ImageAlign="top" or surround it with a div tag. That is not going to work for users. They will never remember to do this. Is this resolved in DNN 4.0.1? |
Buck Anderson
01/17/2007 9:04 AM |
Hello, Yes it would be great to have a jam! - Regarding your second problem, have you tried adding a class to the content pane where you are adding the text / html module and setting it to align to the top? - This way the user will not have to add it each time. 1. - There is something else you really need to check out first, I didn't realise this when I first looked. - View your site in Firefox, the background for the submenu does not display it is just transparent. - I would try to fix this first as it may be a related problem to the spacing issue. - The spacing issue does not occur in Firefox. - Just having a quick look, if you remove from: .MainMenu_SubMenu the height, it will allow the colour to be displayed across the entire background of the sub menus, currently the height is limiting the background colour. Have a double check of the CSS code at skinning toolkit http://www.skinningtoolkit.com/DOTN...fault.aspxThanks, |
