Hello Lee
As an alternative to SOLPARMENU, the more recent DNN:Menu is available.
Perhaps I have been searching in the wrong places, but so far I have not been able to find a great deal of information about it.
I kow that:
- DNN:Menu is XHTML complient
- The header tag fix is: Register TagPrefix="dnn" TagName="NAV" Src="~/Admin/Skins/Nav.ascx
- The skin object code: dnn:NAV runat="server" id="dnnNAV" providerName="DNNMenuNavigationProvide
However, I am not certain of the specific css classes required, or set up configuration.
Perhaps in your 'todo' list you might consider including DNN:Menu as an added addition to your excellent "Skinning Toolkit".
In the meantime, can you perhaps direct me to example of css classes for: DNN:Menu, both vertical and horizontal. Perhaps also how the menu might be configured?
Lynn
