No, that functionality doesn't exist.
However ...it wouldn't be too terribly hard to do. You'll have to know some programming. I'd start with Joe Brinkman's article at
http://blog.theaccidentalgeek.com/p...Nuke.aspx. This shows you how to display a single profile. I'd wrap that inside something that selects all of the users in a role.
I've actually "sort of" done this for another application (using Razor). Here is my sloppy Razor code. You can install a Razor Host module on an administrative page, and paste the code in as a new script. The first line of the script shows how to specify the role, in this case it is "subscribers." You'll have to work a little bit harder if you want to have the role selectable.
@using DotNetNuke.Security.Roles
@using DotNetNuke.Entities.Users
@using DotNetNuke.Common.Utilities
@using DotNetNuke.Entities.Profile
@using DotNetNuke.Entities.Portals
@using System.Web
var users = (new RoleController()).GetUsersByRoleName(Dnn.Portal.PortalId, "Subscribers");
@foreach (UserInfo user in users)
@Server.HtmlDecode(@GetFormattedProfileProperty(user.Profile, "Biography", "
{0}
@functions {
public static string GetProfileUrl(UserProfile profile)
string strPhotoURL = Globals.ApplicationPath + "/images/no_avatar.gif";
ProfilePropertyDefinition objProperty = profile.GetProperty("Photo");
if (objProperty != null &&
string.IsNullOrEmpty(objProperty.PropertyValue) == false &&
objProperty.Visibility == UserVisibilityMode.AllUsers)
DotNetNuke.Services.FileSystem.FileController objFiles = new DotNetNuke.Services.FileSystem.FileController();
DotNetNuke.Services.FileSystem.FileInfo objFile = objFiles.GetFileById(int.Parse(objProperty.PropertyValue), objProperty.PortalId);
// There is a bug in the Photo profile property that stores the host photo
// in the Current Portal and not in the host portal (-1). To overcome this
// bug we just look in the current Portal if we can't find a photo in the Profile Portal
if (objFile == null)
if (objFile != null)
PortalInfo objPortal = (new PortalController()).GetPortal(objFile.PortalId);
if (objPortal != null)
strPhotoURL = string.Format("{0}/{1}/{2}", Globals.ApplicationPath, objPortal.HomeDirectory, objFile.RelativePath);
return strPhotoURL;
public static string GetProfileProperty(UserProfile profile, string propertyName)
ProfilePropertyDefinition objProperty = profile.GetProperty(propertyName);
if (objProperty == null || string.IsNullOrEmpty(objProperty.PropertyValue)) return string.Empty;
return objProperty.PropertyValue;
public static string GetFormattedProfileProperty(UserProfile profile, string propertyName, string tagformat)
string propertyval = GetProfileProperty(profile, propertyName);
if (propertyval != string.Empty)
return string.Format(tagformat, @propertyval);
public static string GetFormattedCityState(UserProfile profile, string tagformat)
string theCity = GetProfileProperty(profile, "City");
string theState = GetProfileProperty(profile, "Region");
string theString = string.Empty;
if( theCity != string.Empty )
theString = theCity;
if( theState != string.Empty )
theString += ", " + theState;
else theString = theState;
if (theString != string.Empty)
return string.Format(tagformat, @theString);
