<!--[if gte mso 9]>
Normal
0
unctuationKerning/>
false
false
false
ontGrowAutofit/>
MicrosoftInternetExplorer4
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:36.0pt;
mso-footer-margin:36.0pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
<!--[if gte mso 10]>
I’ve come to the conclusion that 1ShoppingCart can not
handle third party data and organise it into different Auto Responders. This
seems stupid as we forwarding the exact same data – see attached code.
I also concluded that the Aweber tech support where superior
in promptness, knowledge and quality, one 1shoppingcart support staff told me
he was only trained in following the prompts on the website – had no knowledge
in assessing any data from code.
So; How the Heck is Autoresponders used at the 500,000 Dot
Net Nuke sites around the world?
I have now set up the 1shoppingcart form in a *.html file
and the “IFrame Module” on these sites;
http://www.conniehansen.com/Home.aspx#subscribe
http://buyyourcar.com.au/Home.aspx#guarantee
http://www.mepstar.com/Home.aspx#subscribe
This seems to be working, but it makes the registration a
2-step process, (real bad at “buyyourcar.com.au” where we then need a third
process to become a subscriber.) and it makes the “Dynamic Registration Form”
superfluous again.
I have again attached the code – just in case someone can
pick up an error any different way to submitting the data?
https://www.mcssl.com/app/contactsave.asp
merchantid=172223&ARThankyouURL=www.mepstar.com&cop yarresponse=1&custom=
0&defaultar=524692&allowmulti= 0&Name=$(FirstN)&Email1=$(Email)
ANY IDEAS ARE WELCOME!!!
Cheers
Olle….
