Here's some more skinning issues.
Playing with XD Design Skins -
http://www.dnnskins.comAll seem to be using the SolPart Menu.
The skin is on www.conniehansen.com - but I put up several of the XD Design skins here www.liveforlifenow.com for testing.
On several of these skin the submenu's are disabled - or not there.
Is it possible with reasonable effort to reinstall sub menu's?
On the conniehansen.com site I have a vertical menu that I want to position higher up on the page.
I found only *.ascx and the CSS files in the skin zip, also the classes "pagemaster" "skin master" - token and id for the solpart menu, but no positioning.
Seems a bit different from Lee's xml and html files?
Is this doable with reasonable effort - and knowledge?
Cheers
Olle...
