You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Problem with DNN; 05.03.01 (7)
Last Post 05/12/2010 7:10 AM by
. 9 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
ollep
04/29/2010 7:24 PM
I noticed that you had a problem the other day Lee.
Yesterday my websites with this DNN was down for a while, when Resellers got them back up there was a not about "CRITICAL UPDATE" on them.
Which is the latest update tutorial, one that's applicable for this version??
Cheers
Olle....
DNN MVP
05/02/2010 5:58 PM
I'm not sure what the question is. The most recent version of DotNetNuke is 5.4.1, and it seems to be an ok version.
Joe Craig,
Patapsco Research Group
Complete DNN Support
ollep
05/03/2010 4:33 PM
Hi Joe!!!
I Don't know what the problem was either, but three sites with the new installation suddenly was down.
Reseller Choice didn't give any explanation, just said; "The problem should be fixed now".
The sites where back up, but with this note;
Cheers
Olle....
PS... Hmmm, yes there are a later version.......
DNN MVP
05/03/2010 7:31 PM
"Critical Updates" refers to the fact that upgrading to a later version of DotNetNuke will fix a security issue.
Joe Craig,
ollep
05/04/2010 1:16 AM
OK Joe - better go and do that update then.
What tutorial is applicable for that Joe?
How to Upgrade DotNetNuke (Auto Merge Method) (v4.6.2 to v5+)
How to Upgrade DotNetNuke (Manual Method) (all versions)
Cheers
Olle...
DNN MVP
05/04/2010 4:01 PM
If you are starting from 4.6.2 or a later version, ALWAYS use the auto-merge method.
ALWAYS make backups of the database and the web directory before starting.
Joe Craig,
ollep
05/05/2010 6:12 PM
Thanks Joe
I'll check this one...
Cheers
Olle..
nguyentantaintt
05/11/2010 10:26 PM
I am using store module of DotNetNuke, I need to change currencies from the dollar show to Vietnam for the same. eg I want to change from 15,827.00 to 15,827 (not use 1000 separator) thanks
ollep
05/12/2010 3:35 AM
Sorry nguyentantaintt
I'm not able to help with that one.
Maybe you should put the post under a new topic.
Cheers
Olle..
DNN MVP
05/12/2010 7:10 AM
Which version of the store module are you using? There should be a currency setting.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
