http://www.liveforlifenow.com" target="_blank" rel="nofollow">
http://www.liveforlifenow.com Yes it works - all the time with the Skins.
Not so reliable with the containers????
I can do the FTP install Resources and it finish successfully, but often the container doesn't show up in the list. I do a conventional on site install and get notified the container is already installed - proceed with "Repair/Install" and it's fine.
I'm doing the Skin TESTING HERE:
http://www.liveforlifenow.com If someone want to have a look and comment.
I noticed with all this "DNNSKINS" I'm testing that they do NOT have any SUB-Menus???
Also, REGISTER, LOGIN and LOGOUT are in the bottom only???
Are there a simple way to make the SUB-Menus visible???
NOTE: Most pages are Skin Testing, not only under the "SKIN TEST" tab.
Cheers....
http://www.liveforlifenow.com/Install/Install.aspx?mode=InstallResources
FB5ClubCard
FB5DragonFly
FB5FreshiFresh_UnZipMe_Retast9p
FB5Liquidity_UnZipMe_cHeke3u9
FB5PinkFloat_UnZipMe_7hAdre3h
Install Resources Status Report
00: - Installing Optional Modules:
00: - Installing Optional Skins:
00: - Installing Package File FB5LiquidityS: Success
00:00:00.578 - Installing Optional Containers:
00:00:00.578 - Installing Package File FB5LiquidityC: Success
00:00:00.656 - Installing Optional Languages:
00:00:00.656 - Installing Optional Providers:
00:00:00.656 - Installing Optional AuthSystems:
00:00:00.656 - Installing Optional Packages:
Installation Complete
